Don't install those UCA's Drew! A friend has that style on his car. They hit the shock tower worse than stock and they're soooo heavy. Skunk2 EF UCA's are the way to go.
Sound system and bushing kit looks nice though. What did you fill the trailing arm bushing with?
Imma install them anyway, im not going too low, they look strong enough they can bang a nice dent by them selfs lol, thats actually the front engine mount, its aluminum urethane, 83D
The bolts are down. They hit because they stick out too far. When they made them square on the ends it was a bad idea. It looks like some mini-truck guys "designed" them. The problem is, these arms are so strong, they will damage your shock tower before they break themselves. His is lowered and his shock tower on one side now has a split in the seam from them hitting so harshly.
hmm, well i havent had problems with the stock ones hitting yet, so i hope ill be good
that's what I'm trying to tell you, these stick out farther, so they will hit where the stock ones don't. If you look and compress the stock UCA up far enough, you'll see that just like the tip of the arm hits the fender lip, maybe a 1/8". These stick out farther so it will be violent. If they're like what my friend has, your suspension travel will end when the control arm touches...when it should have another inch or so.
