gotcha what suspension do you plan on going with?
1990[H]accordex : 1992 Accord EX
So this is just a quick post to everyone on cb7, i'm laying off my MRT for couple months, because i'm low on cash and I had lay my car up for rest of the winter, plus my car needs to much for inspection and can't afford it at the moment, i need new upper ball joint, wheel bearing, tie rod end, flex pipe, and catelic converter, only plus of this down fall is my old 1990 accord i pretty much swap all the parts over because they are new on the older one, so hopefully i'll be up and running again in afew months anyways later...
Well as I stated above I'm not running the car at the moment, but I've seem to find little things here and there, to do to it to make it much more unique, and here's another Idea i came up wit
So I like amps with the neon tubes inside them and that they are see threw and that you see the guts and whatnot, so consider I'm low on cash and can't afford one these I did my own little diy on my amp.
First I took the bottom plate off my amp, and replaced it with a piece of Plexiglas and painted it with VHT nightshade...
Them I took old set of blue neon lights I had, cut the wire spliced it together made it shorter and put one light in each corner of the amp and drilled a hole out the side of the amp to let the wire go through...
and this is the results of the lights inside the amp with the tinted glass on it...
...this is not the end tho, I still have a toggle switch with blue led light on it that will hook up to the amp to turn on but this far as i got, and you can believe that this works because i had battery in my room that i used to test this out
So here it is i worked on this for about a week, I got the bumper off my 90 accord ex, repainted it with semi gloss black beauti-tone paint clear coated the whole bumper, then took a jig saw and cut holes out in the bottom of the bumper to put my fogs lights in, made L shaped brackets out of steel bolted them to the bumper then mounted the fogs in ajusted them up and this is the final results, oh and i put a 90ex grill in with diy mesh
