![](http://i317.photobucket.com/albums/mm400/richie33914/newpiccb7.jpg)
Underhood:
-Basically stock f22a6
-No name cone style air filter
-Year old valve cover paint
-Year old exhaust heat shield paint
-Tons of new gaskets
-316,3xx miles*. No smoke, no ticks, no knocks, no bs.
-A/c works something fierce.
*as of 7/10', mileage subject to increase, see odometer for details.
Exterior:
-17 year old arcadia green pearl paint (bg30p-3)
-Custom grey primer passenger side front fender
-Madico 35% Bronze high performance window film
-Various custom scratches, dings, and clear coat fade
-Oem sunroof visor
-Oem rear wing w/ led brake light
-Jdm g square grill (color matched)
-Ebaydm cd5 “type r” front lip
-Jdm 92/93 one- piece headlights, blackhoused w/ yellow highs and amber comers
>Xentec 8000k hid low beams *now using 6000k
>Nokya 2500k halogen high beams
-Jdm intersection lights w/ “maxy” relay and silver stars off in them tricks yo.
-Usdm 92/93 foglights w/ xentec 3000k hid h3’s
-Jdm cb3 side markers
-Depo red/clear taillights
-Edm rear fog
-Jdm power antenna w/ half mast relay
-Jdm accord inspire badge- the real joint without the white back ground
*to be installed
Suspension:
-Tokico rak-501 illumina coil over system
-Energy Suspension complete bushing kit*
-Ebay derived upper and lower ball joints
-No name front camber kit
-Wicked tuning rear camber kit*
-No name front strut bar
-No name rear strut bar
*to be installed
Rolling gear:
-Oem 15” ex wheels w/ 195/60/15 Michelin pilot exalto a/s
-Sportmax 17” 786 wheels w/ 215/40/17 Avon tech m500
-Dayton reverse 13” 80 spoke triple gold w/ 185/70/13 whitewalls….nah, just playin
Ice:
-Eclipse cd3200 deck
Front Stage: Image Dynamics ctx6.5 components
Rear Fill: Oem speaker grills with no speakers.
Sub: RE Audio SE/x 12d2 in 2.2@33 via 4" aeroport
Amp: MB Quart 4125
Electrical: stock alt, stock batt. All power runs & big 3 done with 100% ofc 0ga. all speaker wire 14 ga knu, except sub-its 12 ga.
Other: Mad sound deadening and mlv. My cb7 is quiet and has no rattles whatsoever.
Interior:
-Da teggy tan cloth headrests (to match my shiet)
-Jdm cb3 foglight dash switch
-Jdm teggy rear fog console switch
-Jdm cb3 half switch
-Edm cb3 seat heater switches (2)*
-Custom “red/clear” door courtesy lights
-Broadway 270mm convex blue rear view
*installed, powered up, but no seat heaters. Come on, I live in Florida
Problems:
-Only thing that doesn’t work on this car is the cc. I think I have narrowed it down to the
Control unit or its relay *****Update: I have ruled out the relay and control unit. It gotta be my steering wheel switches!
-Slow trunk leak, I have done everything except reseal the rear window…what gives?*****Update: I fixed that mess. Now my trunk want lotion....
Future plans:
-All bodywork (ding removal, no rust on this thing)
-Fresh arcadia w/ PPG base/clear, wet sanded and buffed
-Bronze 35% tint (mid 90’s Lexus oem looking if you will)****Update: new Bronze 35% film added 7/26/10
-H22a and lsd transmission
-finish my trunk makeover
-Battery relocation
-Finish the audio makeover****Update:system complete 5/21/10
-Keep it clean*
*And install all the crap with asterisks on my list
Heres a few pics for now. Bare in mind this mrt is under construction. I have many install pics id like to add later-but i believe I meet the minimum requirements for now. Let me know what you think, good bad or ugly. And yea, I think the wheels will wind up bronze, they are a little loud for my taste im thinking....Better pics to come, the weather sucks here right now.
Oldest pic of the car, this is when i first bought it, only mod was a tune up and oil change, it had 299,xxx on the clock. This was before I knew about anything about cb7 tuners. Can you say .....stock?
![](http://i317.photobucket.com/albums/mm400/richie33914/stock.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/newcb5.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/hids.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/newcb6.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/newcb73.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/cb79.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/motor.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/cb77.jpg)
![](http://i317.photobucket.com/albums/mm400/richie33914/cb710.jpg)
