I currently have a 3 row but due to space I was forced to use a pusher fan. Car temps go to 215f when sitting at a light other wise it's drops to 198 when moving. I just bought a 2 row koyo half size , but I don't know if the fan I have will fit as a puller.
Raf99 : 1993 Accord EX
Originally posted by Tishock View PostWhat size is the fan and what's the CFM on that fan? You'll want to be around 1600 CFM for a 4banger. Also not trying to insult your intelligence but did you make sure its blowing in the right direction? Is it a puller, pusher or 2-way/reversible?
Yup, I'm also running the cx-racing radiator (see sig), their shroud and I believe a flexalite 2k CFM fan. Going on 4 years now. Had the first one another 3-4 years before a large piece of metal went piercing through it on the fwy. Have also installed them in a couple EGs with no problems. I assume the manifold is deceptively closer to the radiator than it looks in the pic in your MRT and probably runs a lot hotter than my header. Because it almost looks like you have enough room.
Originally posted by Tishock View PostYup, I'm also running the cx-racing radiator (see sig), their shroud and I believe a flexalite 2k CFM fan. Going on 4 years now. Had the first one another 3-4 years before a large piece of metal went piercing through it on the fwy. Have also installed them in a couple EGs with no problems. I assume the manifold is deceptively closer to the radiator than it looks in the pic in your MRT and probably runs a lot hotter than my header. Because it almost looks like you have enough room.I will post some pics on my members ride thread so you can see the clearance. I don't want to further thread jack , sorry raf.
Originally posted by Tishock View PostI assume they need to look at the gear first before they can quote you anything or did they give you a quote? I was going to suggest sending it to Synchrotech or buying one of their already machined gears. But I just remembered you're in the Great White North.
Originally posted by laz93se View PostI currently have a 3 row but due to space I was forced to use a pusher fan. Car temps go to 215f when sitting at a light other wise it's drops to 198 when moving. I just bought a 2 row koyo half size , but I don't know if the fan I have will fit as a puller.Originally posted by laz93se View PostI will post some pics on my members ride thread so you can see the clearance. I don't want to further thread jack , sorry raf.
Originally posted by laz93se View PostNaa, don't mind at all. You running half rad too?
No cooling issues at all. My fan is in the front pushing air through the rad, and I'm using a block off plate beside the rad (<-- this is a must for half rad as air will take the least resistant path).
Originally posted by laz93se View PostI might have to do that block off plate like you did. Did you have any cooling issues before it.
That's sucks about the brake booster, I can't laugh cause I my have to change mine pretty soon.
Originally posted by oni_cb7 View PostJust noticed that there is no dust shield behind your brake rotor. Are there any negative side affects to this? Does it help with cooling the rotor?
Negative affects = dirt/rocks/ between pads and rotors causing you to scratch or mess up your rotors.
Positive affects = Save $ (assuming yours are swiss cheese)
Originally posted by Raf99 View PostThe dust shields are there to prevent dirt, rocks, dust from getting between your rotors and pads and protect that area as well. But I don't drive the car on dirt roads and to replace my old ones was $60-$70 a piece I believe. So I don't use them
My problem is that after brake jobs, the rotor sometimes touches the dust shield and causes a very annoying repetitive sound. I was just wondering if you noticed anything that may cause problems from not having the dust shield. I am tired of fixing the contact issue and have bent the dust shields so many times.
Next time I have the chance, I will probably remove them. Maybe it will help with cooling the rotors
