Shit that was a fast decision, best of luck to you! What kind of goals are you expecting from next week?
Raf99 : 1993 Accord EX
Be unique, like every other person.
CB7 Sold________________________E34 Sold________________________E39 Current
Originally posted by XCRN View PostShit that was a fast decision, best of luck to you! What kind of goals are you expecting from next week?
Originally posted by DCB7 View PostPhotoshop test fit? so no chance of seeing the lights installed anytime soon
You should set them to just halos and fogs, imagine that in the mirror..
Then hit turbo
Hmmm.. just fogs and halos is possible, but there will also be DRL while driving. May have the lights installed in two weeks after the turbo is done.
Originally posted by DCB7 View Postyeah drl might be too much,
I would be interested to see pics when done
Helped buddy install his Billy Boat exhaust on his CTS-V tonight. Was a tight fit and hard to get pieces lined up but in the end it turned out perfect and sounded amazing with that Corvette engine!
[IMG][/IMG]
I'm assuming everyone likes pictures
There are some issues.
1. I need a front ESP traction control bar ASAP. The 3" exhaust will not fit down there with the front cross member in the way.
2. I need a front ESP traction control bar ASAP. The alternator relocation kit will not work with the front cross member in the way.
3. I need piping, no worries here.
Originally posted by aww_shiet View Postnice snail
Originally posted by laz93se View PostOoohhhhh, I like I like. I had to order the esp traction bar too for my top mount.
Well I started this because the one shop I found who could redo the whole rear seats wanted $700, and because no-one sits in my back seats anyways
Started to take them apart and quickly said fook that, as the C-clips are a pain in the butt to get off and on without the proper tools and the styro foam is glued on.
Some may wonder how the arm rest comes out. It has a C-clip type thing on one side
Yep, will paint with it on the seat.
One more coat and it should be good. Here's the corner pieces done. Not that you can see them
