No worries. I gave it a lot of thought and I'm simply going to buy a power distribution block to split the power between the starter / fuse box / alternator. Also thinking a lot, the alternator in the OEM setup feeds from the fuse box. And only needs a 80AMP fuse. The components get their power straight from the ALT. I think my mistake here is due to wire distance and not having the alternator and fuse box share the same distribution point + cheap ebay junk things are not working.
I thought about feeding the ALT from the fuse box again but I think the wire length is too much. So I bought a 3 way power splitter. The battery will have a breaker on it in the trunk, then to 3 way splitter in the engine bay and the 3 splits will be starter, ALT, fuse box.
