JoshM : 1992 Accord EX
    Originally posted by 10thAnnCB7 View Post
    I should probably put that somewhere in the engine bay.
    Maybe the intake or the underside of the hood.
      Originally posted by JoshM View Post
      Check Out My Work In Progess . . . . .
        That would be nice! I'd say the underside of the hood!
        1990 Accord EX
          Underside of hood ftw
          [IMG]http://i166.photobucket.com/albums/u105/akona21/cb2-2.jpg[/IMG
            True. I already have a TAS sticker on the intake. I'd feel bad taking it off. lol
              Underside of hood FWT!
              :EDIT: FTW!
              1990 Accord EX
                "For Win The"?
                  I'm leaning that way now. New_Beginnings has told me about this in the past, and has reminded me of it. Awaiting prnonvtec4u's reply on how to mount them without having visible screws poking out of the front of the bumper.
                  elementary watson, just use the OEM fog light mounting locations, there's about 4 of them all around that area. I'd cut a circle in sheet metal, put the fog through it, and screw the sheet metal to the 4 mounting holes for the oem fogs.
                  you can see the little pegs where a screw would go around the hole to mount the oem brackets.
                  not necessarily have to do it my way, but I would def look into using the oem mounting holes--so convenient!
                    Oh, I didn't think of doing it that way. lol
                    I was over examining it.
                      "For Win The"?
                      Fixed!
                      1990 Accord EX
                        New exhaust on.
                        Pictures to follow on Thursday.
                        Sounds amazing. Nice low rumble, very little rasp at higher RPMs.
                        Only downside:
                        There's a portion of the piping that's about an inch off the ground. So, as you can guess, it scrapes a lot. So bad that before Nic put on close hangers to lift it up a bit, it scraped on flat ground.
                        Luckily it'll be fixed on Thursday. Nic's friend is going to tuck that prtion of the exhaust much closer to the under body of the car.
                        As I was driving to my work so my fiance could get her car, we passed in front of the police station. Of course it's an area that cops are frequently at.
                        Passing over a railroad track, my car bottomed out and sparks went flying everywhere from the piping. A cop happened to be close by, because I saw blue lights as soon as I noticed sparks. I got pulled over, got a warning, and the cop actually laughed at how low my car was. I guess it could have been worse.
                          Dam man and you want to go even lower than that right ? At least it was a warning bro
                            I think he's going to get slightly bigger rims and raise it up an inch. That's crazy how you got pulled over soon after putting it on though.
                              I say leave car as is and get a set of 16's OEM Acura 5 double spoke wheels!
                              That's your cue JoshM. PM me.
                              RETIRED...
                                My bad for running out of gas on the welder. You were right, I shouldn't have been practicing. all will be cured thursday.
