HappyGilmore : 1992 Accord EX
    I have still have to Konis on it from when I bought it, but the plan is to go with Tokiko coilovers and diff shocks as well
    The CB7 Collector.
    92 LX Coupe F22A1
    2013 Toyota Corolla S
    92 EX Sedan F22A1
      Need to get one more EX rim...and paint it black with the OEM caps on there
      The CB7 Collector.
      92 LX Coupe F22A1
      92 EX Sedan F22A1
        The CB needs new bushings all the way around...this would explain my unusual ride height all the way around....posting pics later
        The CB7 Collector.
        92 LX Coupe F22A1
        92 EX Sedan F22A1
          Goals this summer:
          5 Lug swap (this includes bigger rotors)
          Wire Tuck
          New Paint Job
          Finish Interior Swap
          Susp. Refresh all the way around...
          Gun Metal Grey Rims of a 8th Gen Accord
          The CB7 Collector.
          92 LX Coupe F22A1
          92 EX Sedan F22A1
            Sad day today--Alternator bolt snapped and changing the IACV (to get rid of this damn idle issue.)
            The CB7 Collector.
            92 LX Coupe F22A1
            92 EX Sedan F22A1
              Cams are making noise + Valve lash = Happy isn't Happy
              Brakes all the way around are grinding
              Need new wheel bearings (All the way around )
              Need to pick up the OEM fogs from Mike!
              5 Lug swap is in store for this baby with brake upgrade
              Sups bushings need all the way around
              Not giving up on this-----even though there are those days....
              The CB7 Collector.
              92 LX Coupe F22A1
              92 EX Sedan F22A1
                Rods have been thrown in my H22...Valve job is good everything else bad, I almost want to give up her. What should I do....
                The CB7 Collector.
                92 LX Coupe F22A1
                92 EX Sedan F22A1
                  How did that happen? Sucks man.
                    what you should do is, keep your head high, cuz you have a h22 coupe cb, and the forum to back you up if you need anything.
                      I have good news: I was informed that my LMA's might be out after valve adjustment and that this can happen sometimes. In other words what I thought was rod knock isn't rod knock at all. I rather excited and i just know I have alot of work ahead of me now...
                      The CB7 Collector.
                      92 LX Coupe F22A1
                      92 EX Sedan F22A1
                        Lessong be learned when doing your flywheel: Make sure that you torque your flywheel at the correct specs (I thought I did but evidently I was wrong). I even did the proper research and I mangaged to miss the specs and so my flywheel bolts backed out and caused my clutch to not disengage. It's a good thing and a bad thing all at the same time for this reason: 1. I had some help this time around. 2. I am putting my F22A1 tranny on my H22 3. I now know how to properly use a torque wrech (which I should have learned that in the first place 4. My partner better understood how a manual transmission works.
                        Now I am changing the UCA's and I am moving the perches on my suspension and placing the SE rims on this one and my Konigs on my Coupe that I just got recently as I am making drasitic changes in such short period of a time!!
                        That is all for now!!
                        The CB7 Collector.
                        92 LX Coupe F22A1
                        92 EX Sedan F22A1
                          sick car! What size exhaust tip is that?
                          ^Clicky for MRT
                          Kelowna Rhinoplasty and Gozie.com.
                            4 in Megan racing tip
                            And F22A tranny swap done!!!!!
                            The CB7 Collector.
                            92 LX Coupe F22A1
                            92 EX Sedan F22A1
                              This is what caused the weird noise (or what I thought was rod knock). Now she runs super healthy the healthiest I have ever heard/seen this car run. Here are some pics enjoy.
                              The CB7 Collector.
                              92 LX Coupe F22A1
                              92 EX Sedan F22A1
                                Funny how that works. Glad it wasnt worse.
                                Originally posted by Jarrett
