93F22A6 : 1993 Accord EX
Dude, that lip looks hot! Need to do the sideskirts and molding then it'll be too hot to touch homie!Still hustlin that Old Skool.......it never ends.
vv My Member's Ride Thread vv
http://www.cb7tuner.com/vbb/showthread.php?t=123371
Originally posted by 93F22A6 View PostWhen? I will be back near cameron on the 26th.
ill let you know tho
Originally posted by The-Gr8-Ox View Postamazing, good job
now take the viper emblems off and put side markers i there!
"The Turtle"
DD/Trail Rig/Mud Bug
Holy Snow
Well this was the first time the CB had been snowed on in a long time, it might of even been the first time as well, not sure.
The first two are greenish ecause I was messing with the camera and couldn't see, plus it was damn cold.
"The Turtle"
Update: Change the oil pressure sending unit that about killed my CB. Gutted the cat because I was bored, little difference in sound not so much power. (note it is not as easy as it seems, I recommend to use a long pry bar, BFH (big F**kin Hammer), and an air chisel) Also messed up two exhaust studs on my fail attempt at installing a DC Sports Header(took it back off gave me to many problems). I also installed a DIY short shifter, works great. Had to cut the console in the middle to clear though.
"The Turtle"
Originally posted by 93F22A6 View PostUpdate: Change the oil pressure sending unit that about killed my CB. Gutted the cat because I was bored, little difference in sound not so much power. (note it is not as easy as it seems, I recommend to use a long pry bar, BFH (big F**kin Hammer), and an air chisel) Also messed up two exhaust studs on my fail attempt at installing a DC Sports Header(took it back off gave me to many problems). I also installed a DIY short shifter, works great. Had to cut the console in the middle to clear though.
Nice man, where you been?Still hustlin that Old Skool.......it never ends.
"The Turtle"
Originally posted by Shadow1 View Postgutting your cat out wont give you no gains man. just an annoying sound. lol.
how you been? you coming with everyone on sunday to my meet?
"The Turtle"
