cloudasc : 1991 Accord LX
    Completely "Refurbished" Head (New Exhaust Valve Guides, Retainers, Bisimoto Pro Race Springs, Valve-Job, etc), ARP Studs, Ishino/Stone Headgasket
    *Completed: 7/10/2009
    CHR p&p doublestack hybrid intake, bisi intake gasket, unorthodox pulleys, &
    a6 cam/oil cooler/windage tray/pt6 upgrade, oem stanley fogs, polished valve cover
    *Completed: 4/18/2009*
    Pictures on pages: 1, 2, 3, 4, 5, 6, 7
    Mod List:
    Fluids:
    -Royal Purple Synthetic 10w30 Motor Oil - Last Changed @ 187k 4/2009
    Flushed: 180k
    Changed: 187k
    -Honda Genuine ATF @ 180k 4/2009
    Flushed: 155k
    Drain & Fill: 180k
    -Penzoil ALL Make/Model Coolant
    Flushed: 180k w/ Purple Ice (up to 20% cooler) @ 180k 4/2008
    -87 octane unleaded
    Fuel Injectors Cleaned: 155k
    Fuel System Cleaner: 172k
    Fuel Filter Replaced: 178k 4/1/2009
    Engine Info:
    -f22a1 block *stock*
    -All new Honda Oil Gaskets and Seals @ 180k 4/18/2009
    -Ishino/Stone Headgasket @ 184k 7/2009
    -Completely "Refurbished" Head @ 184k 7/2009
    -Bisimoto Pro Springs @ 184k 7/2009
    -Polished Valve Cover @ 180k 4/18/2009
    -a6 oil cooler @ 180k 4/18/2009
    -a6 windage tray @ 180k 4/18/2009
    -a6 cam @ 180k 4/18/2009
    -CHRRacing P&P a6 lower intake runners @ 180k 4/18/2009
    -CHRRacing P&P h23 upper intake plenum @ 180k 4/18/2009
    -H23 60mm Throttle Body @180k 4/18/2009
    -New FITV @ 180k 4/18/2009
    -pt6 ecu @ 180k 4/18/2009
    -Resoldered PGFI Relay @ 138k
    -Aluminum Radiator & New Hoses @ 140k 2/2008
    -Denso O2 Sensor @ 179k 4/2009
    -K&N Air Filter @ 174k 1/2009
    -K&N Oil Filter @ 174k 1/2009
    -JDM Mugen Radiator Cap @ 145k 2/2008
    -JDM Mugen Oil Filler Cap @ 145k 2/2008
    -JDM Mugen Thermostat @ 177k 3/2009
    -JDM Mugen Fan Switch @ 177k 3/2009
    -Unorthodox Ultra Sc Crank Pulley (Stock Diameter) @ 180k 4/18/2009
    -Unorthodox Ultra A P/S Pulley @ 180k 4/18/2009
    -NGK Laser Platinum Plugs @ 150k
    -NGK 8mm Plug Wires @ 179k 4/05/2009
    -All New Air Conditioning except piping. @ 157k 5/2008
    -All New Valve Cover & Spark Plug Oil Seals @ 157k 5/2008
    -Interstate Battery @ 165k 8/2008
    -Alternator @ 170k 11/2008
    Exhaust:
    -Stock A1 Exhaust System
    Suspension:
    -Four Wheel Independant Suspension *stock*
    Alignment @ 174.5k
    Drivetrain:
    -4 speed automatic transmission w/sport mode *stock*
    Traction/Wheels:
    -15" Enkei 16 Spoke Honda Motor Co., Ltd Alloy Rims from 86-88 Acura Legend @ 150k
    -Federal P195/60R15 @150k
    -New PS Front Disc @ 143k
    -DS Resurfaced @ 143k
    -New Front Brake Pads @ 143k
    Exterior:
    -Performance Trends Blackhoused Projector One-Piece Headlights @ 125k
    -15% Window Tint Applied Sides & Rear @ 142k 4/2008
    -Blackhoused Bumper Turn Signal Lamps @ 171k 12/2008
    -EuroLite 1156 Amber Bumper Turn Signals @ 172k 12/2008
    -DIY Gutter-guard Painted Grill @ 171k 12/2008
    -92 Ex Front Valance *stock lip* @ 177k 3/2009
    -OEM Stanley Fog Lights, Harness, & Switch @ 180k 4/18/2009
    Interior
    -Gray Cloth Interior *stock*
    -Sunpro Universal Single Gauge Piller @ 179k 4/2009
    -Autometer Oil Temp Gauge @ 179k 4/2009
    -Autometer Autogauge Oil Press/Volt/Coolant Temp Gauge @ 179k 4/2009
    Electronics/Misc:
    -JVC DV5300 DVD/MP3 DIN 10/2007
    -Alpine V12 45w RMS x 4 @ 4ohm 5/2008
    -4x Infinity Reference 6.5" (Shallow Mount for Doors) 10/2007
    -Alpine V12 300w RMS @ 4ohm 500w RMS x 2ohm 5/2008
    -1x 12" JL Audio 12w1 @ 4ohm (Custom Sealed Box) 5/2008
    -Audiovox Prestige Alarm 10/2007
    -Rust Evader System *came with car
    -150W Power Inverter
    Future Plans:
    -- Engine --
    Balanced & Blueprinted Rebuilt F22A Shortblock
    Golden Eagle 86mm Sleeves
    Bisimoto 12:1 Forged Pistons w/Moly Coated Skirts
    Bisimoto Forged H Beam Rods
    OEM Honda Bearings
    ESP Traction Bar w/ Front Torque Mount
    ESP Poly Motor Mounts
    AEM Cold Air Intake w/ Bypass Valve
    Bisimoto Cam Gear
    Bisimoto Stage 2.5 Camshaft Regrind
    -- Exhaust --
    Bisimoto Stainless Steel Ceramic Coated Header *Purchased*
    Venturi 2.5" in / 3.0" out
    Magnaflow Spun Catalytic Converter 3.0" in/out
    Venturi 3.0" in / 2.5" out
    14" & 22" Resonators 2.5" in/out
    Quiet High Performance Muffler 2.5" in/out
    -- Suspension --
    Koni Yellow Neuspeed Edition Struts & Race Springs 2.25" drop.
    -- Drivetrain --
    H23 Manual Transmission
    Quaife LSD
    -- Traction/Wheels --
    17" Konig Unknown's
    Toyo Proxes T1-R 215/40/17
    -- Exterior --
    Rainguards
    -- Electronics/Misc --
    Hondata S300 Chipped P72 Equivalent
    Laptop Mount Stand
    Multi-Battery Isolator
    Custom Dual 12" Sealed Box
    Second JL Audio 12w1
    Current Dyno Sheet: 110whp @ 6k / 108wtq @ 4.5k
    Exterior Photos:
    After fogs:
    Before Fogs:
    Photos taken in Seattle, Washington (A year ago before lip, grill, fogs, blackhoused turn signals):
    Interior Photos:
    Engine Compartment Photos:
    Before:
    Currently:
    This is a video of park/neutral revving, so you can hear the intake:
    Here is a 0-90 pull video:
    Here is the Dyno Video:
    how those
    hey bud remember me!
    free wheels at the SI meet!
    anyways rıdes lookın good tıme for a lıl change tho what you got next ın mınd?
    MadLab Racing
    Southern Maryland
      great start........
      better than I am when I got my cb...
        drummersteve7 & CB7_ACCORD
        Really old photos (3/2007)
        The car was completely stock until somone put me in their blind spot then tried to merge into me while its wet outside, and this is what the outcome was:
        This is when and why I replaced my headlights
        Insurance Totalled out my car for 3.2k and I got to keep salvage valued at $700, repairs & paint were only $2200, I used the extra money to purchase a new deck & have an alarm installed. Here are the shop pictures:
        The day it got out of the shop:
        Hey Steve! Yes I remember you, thanks for the wheels they held up long enough, one i balded the inside half, and the other was starting to detread on the inside before I got my new rims and tires. I still owe you a cold one though, we should meet up sometime soon! Let me know
        Originally posted by CB7_ACCORD
        great start........
        Thanks all the cars i've owned have been at least 15 years old when I got them, and this is by far the nicest of them.
        Last edited by cloudasc; 01-18-2009, 03:25 PM. Reason: Inserted Pictures of the Past
          nothing wrong with it.....I myself own older cars too...
            =P, well I've been trying my best to take care of my car, got it minty fresh all around @117k miles for 3708 before title and tax, other then the typical rust from on the rear quarterpanels (barely noticable at the moment), I have a picture of me when I got the car, i'll have to scan it and upload it (compliments of the Cadilac of Bellevue, WA)
            Oh and I got new rims, they are from a 86-88 Acura Legend, picked up the set for $100. Got new and had them installed, here are the pics: 4/15/08
              great deal for car with little to no rust....
              I got mine in 06 with no rust and around 96xxx miles...for around the same price... I was happy with it..
                Woo Hoo, just got my car Tinted! Now I gotta wait 3 days to roll down my windows, but thankfully i drive a coupe and have the rear pop outs, plus my ac works =P
                  tint look good..........
                  how much tint was it?
                    The tint was 261.25 after tax, i gave them a tip, that rounded it off to 275, oh and its 15%
                      Nice looking coupe..
                      My Old Baby
                      SOLD TO
                        Thank you very much, I have more up my sleeve for this car in the near future, keep checkin in, next project DIY Grill! I got the gutter guard and the paint! New Grill here I come!
                          where? body shop?
                            where? body shop?
                            Heres your picture reply!
                              And i will be sure to keep checking..
                              My Old Baby
                              SOLD TO
