no..you read you fuckign twat..dont make me expose your fat face like i did before
anyway
since the worlds sensitive..he was thinking that he doesnt have compressor surge JUST cause he has a bov..thats how he worded it..you get compressor surge with
http://honda-tech.com/zerothread?id=1754893
read up on that thread
"Compressor surge is what happens when you're boosting, the turbo has built up all this pressurized air moving at high speed in your intake pipe, and then you take your foot off the gas - the throttle plate closes, and all that air has nowhere to go. If you have a BOV, the valve opens and vents the pressure all out. If you DON'T have a BOV or your BOV is not functioning correctly, all that pressure has to work its way BACKWARDS through your turbo which is still trying to push it forward. This results in very nasty sounds and damage to your turbo's bearings"
you probably have a fucked up bov..if you still have that sound with your bov on
anyway
