plasma cutter
    plasma cutter
    i found out that we have a plasma cutter at work so hopefully i can get it setup and started on making some rear strut mounts for a X brace type trunk bar...w00haa!
    ill keep yall posted
    what....just use rolled pipe and hole cut the ends and weld her up
      wha?
        But can you weld?
        1992 Accord LX - SOLD
          they have plasma cutters at Starbucks? j/k. i guess you don't work there anymore. later.
          Avoiding dirt at all costs
            LOL let us know how it all works out and i'll have a double mocha grande lol
            -sean
            Members ride 15.927 @ 86.76 (f22a1)
            Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
            Arcadia Green Crew #10
              I hear they use the plasma cutters to heat up the coffee of unruly customers. 20,000 degree coffee! Yeah thats a little burn. J/k Where are u working now?
              Arcadia Green Crew Member #9
                holy shit, how did everyone know i worked at starbucks?
                but yea i quit that shit back in may, had problems with management. so far, the plasma isnt cutting correctly. the tip may be worn so ill need to get a set of tips for it. $$$ (not really)
                  because you bitched about it pretty much everyday.
                    oh yea.
                      yes! new tip for the cutter, lets see if it will cut now.
                        plasma cutters are so freaking bad ass. i got to cut a car completely in half with one back in the day.
                        THEY CUT ANYTHING
                          yea i used one to cut a notch out of my front crossmember so my new radiator would fit withough creempping the lower hose
                          Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
                          But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
                            i have one at my school and also access to welders if ya need help let me know
                            Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
                            -(B-Pillar Bar Originator)-
                              i finally was able to cut the strut mounts, im still trimming/grinding them. i need to adjust the air pressure because i have too much slag ugh.
