anyone ever tried Durafix Aluminum Welding Rods?
    just wondering if they're as good as the video says they are.
    later.
    Avoiding dirt at all costs
    wow! vid was quite convincing..
      yeah, they made it look easy. i don't know if these are new or not, but it's the first time i've heard of them. later.
        Thats not welding.... pish. Solder.
        wat?
          more like brazing, which is a form of welding. later.
            yeah I guess, I wouldn't trust it for something real important. I don't see the metals actually fusing together, rather just laying on top.
            wat?
              Yeah, there's no real penetration going on there. It's more like a badass glue. I wouldn't trust this if you're using it in a high heat or anything that will support a lot of weight/tension.
              It will work great with brazing though.
                yeah, i was going to use them to fill holes. later.
                  I usually use my penis for that.
                    LMAO would this work for shaving the side mouldings?
                    clicky the siggy!!!
                    ARCADIA GREEN MEMBER #20
                    AIM=SleepygreenCB7
                    Yahoo=annamaineeak@yahoo.com
                      no, not at all. the door skin is made of mild steel. later.
                        Like welding, a brazed joint, if done properly is stronger than the surrounding metal by a significant margin. So depending on the application, its plenty strong.
                          depends, how sharp is your penis?
                          ____
                            something like if your doing the h-swap and wanna keep the h powersteering
                              I don't think anybody needs any buttholes filled any time soon, but thanks for the heads up.
