This is mainly just all of the info I could find regarding the installation and choice of camber kits. I decided that since I spent a while looking around I would save other people the time and hassle of searching.
FRONT CAMBER KIT
Installation Video: SPC balljoint kit
http://www.iapdirect.com/pictures/adjballjointvideo.wmv
Installation Doc: Ingall's balljoint kit
http://www.iapdirect.com/pictures/35590-35622.pdf
Installation Doc: Ingall's control arm kit
http://www.iapdirect.com/pictures/39200.pdf
Installation Doc: SPC balljoint kit
http://www.iapdirect.com/pictures/67340.pdf
Installation Pics
![](http://images.andale.com/f2/104/128/12637619/2007/1/18/67320.jpg)
Installation Doc: Ingall's bolt style kit
http://www.iapdirect.com/pictures/35660-35730.pdf
Installation Pics
REAR CAMBER KIT
Installation Doc: Ingall's rear balljoint kit
http://www.iapdirect.com/pictures/38811-38832.pdf
Installation Doc: SPC rear arm kit
http://www.iapdirect.com/pictures/67265.pdf
![](http://images.andale.com/f2/104/128/12637619/1102144532906_67265ill.jpg)
OTHER HELPFUL THREADS
4CYLPOWER92's
SUSP: Spc Camber Kit Install With Pics
maroonaccord2.2's
SUSP: Camber Measure and Rear Washer Trick
CustomLowz's
SUSP: Front Camber Kit Install
xplode's
Installing Camber Kit
quickangel93's
SUS: Upper Control Arm/Ball Joint Replacement
iamanonymous's
Susp: Camber Kit Repair
aero's
SUSP: Alignment
and aero's Suspension sticky (about 3/4 of the way down it goes into camber kits)
*** Suspension Thread Index *** Look here FIRST
accordtunerx's camber issues and attempted solution
FYI: problem associated w/ camber kit install (upper control arm, fenderwell)
General Honda Camber kit information
Honda Camber Kit Guide
Thoughts on the Upper Control arm hitting the fenderwell
Info on the newer version of the SPC kit and installation
SPC Balljoint Kit Review
jdm inspired's issues with the Ingall's kit and banging with possible solutions
Ingalls balljoint camber kit hitting frame
Other's Supension setups (good for understanding who needs camber)
WHAT suspension set-up are you running? And how would you rate it?
Other's Camber kits and thoughts
What camber kit's you runnin
A GREAT GUIDE to understanding camber and if you need a camber kit
http://www.hondatuningmagazine.com/t...de/caster.html
Suspension install (how to take off various suspension parts and hopefully put them back on
Suspension Install
Have any suggestions? PM me with anything I should add
Shameless words to get more search results: all camber kit info camberkit positive negative alignment ball joint bolt
FRONT CAMBER KIT
Installation Pics
![](http://images.andale.com/f2/104/128/12637619/2007/1/18/67320_ill_b.jpg)
![](http://images.andale.com/f2/104/128/12637619/2007/1/18/67320_ill_a.jpg)
Installation Pics
![](http://www.ingallseng.com/graphics/Drawings/35720_assemblyline.gif)
REAR CAMBER KIT
4CYLPOWER92's
maroonaccord2.2's
CustomLowz's
xplode's
quickangel93's
iamanonymous's
aero's
SUSP: Alignment
![thumbs up](http://www.cb7tuner.com/thumbup.gif)
![bouncy](http://www.cb7tuner.com/bouncy.gif)
Suspension Install
