Update:
I installed new endlinks on the passenger side. I did not have time to do the driver's side since I also had to replace an upper control arm.
The OP's pictures helped me get the right order combo of washers and bushings. The endlink I removed had way to many collars than the one I installed.
I also used the tip here of tightening the bolt until you couldnt move the you washers. I still think mine is under-torqued at the moment.
Thanks to everyone!
Thanks to everyone!
