Having a 90 5-Speed, I got tired of the "truck like" throw of my shifter and this left me wanting a shorter throw and shorter shifter, and no aftermarket companies make a real short shifter for my car. I did this DIY that can cost no $$ and works great!
I went out and found an extra shifter from an old 90 5-speed just because I didnt want to cut my stock one, anyway, I got some simple pics and directions on how to do this short shift mod.
1) Remove the shifter from the shifter housing
2) Take apart the whole bottom part of the shifter (there are some nylon type pieces that could melt if left assembled during welding process)
3) I used a band saw, but I guess any metal saw would work, cut the mid section out of the shifter
4) After taking the 2 ends to a grinding wheel to make sure the 2 pieces go together well, I welded the top half and the bottom half together (make sure you get a good weld so it dont snap when you go to shift, lol)
5) Re-assemble the bottom section of the shifter you took apart in step 2 (some silicon grease could be used)
6) Re-Install the shifter into the shifter housing and use some silicone grease on all moving parts.
And the finished product, a shorter throw, and a shorter/sport looking shifter.
