Pictures and steps taken from Haynes manual, was a big help to me, hope you guys can see the pics well as they are not very good quality. Rear speakers are farther down.
Wagons are a little different in the rear, I've typed out the process at the end, but sorry I do not have pictures for it.
Front Speakers:
1. Remove the single screw at the rear lower edge of the speaker grill.
2. Then carefully pry the grill off the door trim panel.
3. If you want to remove the entire speaker assembly, remove the four outer mounting screws(arrows); to remove the speaker itself only, simply remove the three inner retaining screws(arrows).
Then pull out the speaker and unplug the electrical connector.
Installation is the reverse of the normal.
Rear Speakers for Coupe/Sedan:
1. Working from inside the trunk, unplug the wires(arrows) from the speaker and remove the three nuts(arrows).
2. Remove the speaker grill retaining screws(arrows) from the back side of the speaker assembly, lift off the grill.
3. Remove the three speaker retaining screws(arrows).
Installation is the reverse of removal.
Wagon Rear Speakers:
Note: There are actually three rear speakers in the Wagon - two in the overhead and a woofer in the left rear corner. The following procedure applies to either overhead speaker as well as the woofer.
1. Open the tailgate and pry off the speaker grill.
2. Remove the four speaker retaining screws, pull out the speaker and unplug the electrical connector.
3. Installation is the reverse of the normal.
Hope this helps for all you audio guys!
Front Speakers:
