EXT: A Complete USDM Black Housing DIY W/ PICS!!! (56K Be Warned!!!)
    Originally posted by djcaz_aom
    1. Remove the side marker retaining screw. Pull out the marker and unplug the bulb connector.
    For those that haven't removed their corners before, you pull FORWARD on the light housing. It may give a "snap" sound. If you pull more towards you (sort of off to the side of the car) you'll break the tab on the housing. It's unfortunately one of those things that's obvious only after you've done it.
      Originally posted by Shadow1
      could you use a heat gun on the headlights instead? i dont think my dad would be to happy to wake up or come home with head lights in his oven.
      sounds like my dad, wait just the though of me working on my honda(to him) would piss him off
      My Ride17.34 @ 78mph with 260k on her
        Very nice I like whats cookin in the kitchen smells good if your really good
          i was wondering... could i do this same DIY to my bumper signal lamps since they are clear too?
          Be Clean
            they already make blackhoused bumper lights..they are all over ebay
            -1993 Accord EX SOLD
            -2012 GMC Canyon V8 4x4
              awsome right up, incase the pictures gets deleted again I went ahead and printed out this thread including the pics dang over 50 pages just for the diy, thanks alot Bro
                Yes you can do your cornersas well. The whole idea of a DIY is that you dictate the out come, not the company that mass produces. Keepan eye out for my corner/ bumper blackout DIY.
                Black Housing DIY 1991 Wagon Morimoto Retrofit
                JDM One-Piece Headlight Lens Repair
                  Check out the added steps and PICS for JDM Yellow high beams!!!!
                    okay i know you paint the top and bottom of inside the headlamps but does it really affect the headlight beam at night? will you be able to see the road as good because the top of the inside headlamp is black?
                    i've already done this DIY but i didnt compare to stock, just wondering, looks great tho
                    Be Clean
                      Does the headlights leave a smell around the house? I dont have a heat gun and never thaught about the oven, I want to try it while my parents are gone.
                      Will's Accord
                        Nope, not really from what I remember....
                        I give this thread 2 very enthusiastic thumbs up!!
                        Nope, there is no affect in output what so ever.... The surfaces that you are painting simply DO NOT assist in redirecting light from the bulb forwards to the road, plain and simple.
                        1992 Accord LX - SOLD
                          ^^^ Ditto; I actually noticed an improvement over stock. There isn't as much glare and the they seem crisper, when seen from afar.
                          Thanks maroonaccord2.2. for the props.
                            i love you... when you spray the yellow stained paint, do you mask off the black?
                              That's completely up to you. The first set I did, were already blacked out, ie. my first set, so I didn't mask them off. They are the ones in the pics. Then the DIY bug bit me again and I did a set for a friend and after pulling the housings out of the oven (after applying the black paint), I just left the masking tape on there and applied the yellow then. I even did a blue and yellow set; all red (Don't Ask) set and red yellow.
                              Just use a sweeping motion and try not to put it on too thick. Then heat cure it the oven.
                                the silicone stinks for sure and will make the house smelly. the spray paint if done outside wont stink up the house. i remember having spraypaint smell in my house... just have air freshner ready when parents are gone. this DIY is fun and worth it, hardest part is taking off bumper
                                Be Clean
