Items needed:
headlight covers (duh) *mine were gts headlight covers*
dremel or rotary tool
sand paper
masking tape
double sided tape to mount onto theheadlights *i didn't do this because the hood will hold the eyelids down*
paint if wanting to color match to car
steady hand
time
Step one:
fit the headlight covers on the headlights and line up the hood line with the covers, and the lines on the headlights. and apply masking tape to make straight line to cut on.
Step two:
after measurments are done, slowly cut using a dremel, along the masking tape, test fit.
Step three:
after cutting on the line of masking tape, carefully go over rough edges with the dremel or sandpaper, test fit again.
Step four:
remove the masking tape and fit the eyelids use double sided tape if needed, close hood and admire your new "t" square eyelids
if anyone is uncomfortable doing this themselves i may be able to do it for a small fee.. of course sending me your headlight covers, i'll cut them and send them back to you.
sand paper
masking tape
steady hand
time
Step one:
Step two:
Step three:
Step four:
