EXT: polishing the stainless steel window trim
    Originally posted by accordztech
    hehe i was always too lazy to do that, i think now ill try it...thats good crazy results!!
    ill do it to my 300zx. haha
    good job.
    just make sure the trim on your 300zx is stainless or at least aluminum.
    if a maganet sticks to it........steel
    if it doesn't.........................aluminum
    to tell if it is chrome, rub metal polish on it. if no black residue appears on the cloth, it is chrome.
    it may also have a plastic coating. no black residue either. if that is the case, use a plastic polish. later.
    Avoiding dirt at all costs
      You still got me thinking I might do this next year once its warmer.
      So I guess it could also be done with polishing cones like these: http://www.griotsgarage.com/search.j...=17&search.y=6
      and an electric drill along with metal/mag polish as already noted.
      '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
      EX Lip & Alpine OEM single CD Player. No more useless pocket!
        true. later.
          i will be doing this as soon as the weather clears up (damn freezing rain) since i have already purchasd all the materials needed..like $15 tops i went to Wal-Mart to get the stuff..i'll post pics afterwards..Great DIY
          Thanks!
          -1993 Accord EX SOLD
          -2012 GMC Canyon V8 4x4
            ^^^don't mention it. later.
              I did this a couple weeks ago and boy does it make a difference
              '04 SB AP2 211whp 150wtq
                Anybody tried to use brasso to do this? I think I will use some brasso I have lying around and see what happens.
                Gary A.K.A. Carter
                [sig killed by photobucket]
                  yo type g, can you post some pics on how to remove the trim from the car?
                    but why, it's not brass.
                    i don't have any. i didn't remove it to polish it, i just taped it off to protect the paint.
                    most trim pieces have a screw or three holding them on with a few plastic clips that break really easy. after you remove them, then you just carefully slide them apart. later.
                      do you have to use an electric drilll/buffer to do this?
                      or could you do it by hand?
                      pros/cons?
                        or could you do it by hand?pros/cons?
                        you don't have to use a drill/buffer, but if you use one, you will be glad you did. stainless is very dense. it takes a lot of speed to polish it. i tried it by hand and it improved a little, but the results where nothing compared to what the drill did. later.
                          yeah, i'm doing it right now.
                          hand buffing it is okay, but the difference between using your hand and using your drill is kinda like night and day.
                          well, on the most tarnished surface.
                            I am going to revive this very old but useful thread.
                            I have a question that is kinda related.
                            I noticed that you don't have the OEM grille anymore, but I was wondering if you have any techniques for polishing the plastic that is chrome plated? I am worried that it will just flake off. Any tips? I also have chrome around my tail lights and headlights that could use some love.
                            CB3 formerly hondaracer33
                              the chrome on the grill is chrome cladding. as you know, it's not as robust as the chrome plating found on metal. i'd use mother's chrome polish to clean it since it's on the mild side, but i wouldn't make a habbit out of using chrome polish on it.
                              for the headlights and taillights, you must first determine the finish, stainless steel, chome, ect. if it's chrome, you can treat it like the grill. if it's stainless, you can use the mag and aluminum polish. later.
                                Thanks alot bro! I will give it a shot and let you know how it works.
