EXT: universal trunk (fits 90-91 AND 92-93 tail lights)
    it took me a while to do this but as promised here it is:
    before 90-91 tail lights
    after 92-93 tail lights (same trunk)
    I'll take you step by step as to what i did to make my trunk universal to all cb tail lights.
    step one
    go to the junk yard and buy this
    its the middle part of a 92 93 trunk and you will definitely need it
    step two
    remove your trunk lights by taking of the 4 caps on each light as seen here
    step 3 (you will need a drill)
    you will need to drill 3 holes on each side to make the trunk lights fit.
    once you drill the holes the trunk lights should pop right in but you will have a bunch of extra space because the 90 91 trunk lights are longer
    now remove the lights.
    step 5 grab the inner part of the trunk that you got from the junk yard
    and pop it in
    its gonna easily fit but to keep it on you will have to drill 1 hole on each side for screws.
    once everything is nice and tightly secure put the lights back on and this time it will look like this
    the license plate will actually help that thing stay on.
    ALSO, notice that you will no longer be able to open your trunk with your key because it is now hidden.
    screw your lights back on, make sure everything is tight and you should be ready to go
    My MRT
    Did you make it to fit 92-93 coupe lights?
      actually that is easier lol, all you really have to do is remove that thing where the key goes and it pops right in with no modification, ill be doing that soon to take pics
      My MRT
        will this work if i have a 9293 coupe and want to put 9293 sedan tails on my coupe?
          as i said you will have to remove that key thingy
          My MRT
            Great write up for those of us that don't feel like swapping trunks.
            1990 Accord EX
              I'll give you credit for actually doing this and following through with a DIY. It yields an inexpensive way to swap tail lights.
              From the photos alone, it seems like the garnish could POSSIBLY be hacked up to fit snug within the 9091 license plate recess.
              It's also a great write-up for those who enjoy modding on the cheap, cheaping out in general, and have little-to-no care for proper form and/or fine details.
              Just saying it like it is.
              To each their own.
              Toodles.
              My pictures/photos will return soon...
                Im going to have to agree with this, is a trunk that expensive to warrant a a hack job to a trunk?
                I'd rather stay 9091 then incoporate all sorts of flaws into my trunk, as well as how water tight is this? I'd imagine not very. Do it right the first time and you never need to do it again is my thought
                  Nice write up. I personally don't care for the round swapped lights. I really like the stock tails lights on Hondas all the way from the coupe,sedan,wagon and the Oddessy. Call me crazy but I do. I also like the headlights. Makes it a Honda. I love the Honda and don't want mine to look anything else. Nothing worst than making a car "look" like another.....V.W. with Rolls grill? Accord into some European thing? No thanks
                  Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
                  New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
                  2000 EX Coupe - Joe -
                  www.AccordWagonClub.com
                  My Facebook Site - ACCORDOBSESSION
                    I always thought it could be done. Except I thought you might be able to just bolt it in no problem.
                    My only recommendation is if you do this, figure out a way to relocate the keyhole.
                    Now, I'm more curious on if this method would work on wagon tail ights. Since I don't believe they make red/clears for the wagons, someone could perhaps do something like this and drop in the 92-93 sedan red/clears.
                      To each their own.
                      Toodles.
                      the whole point of this is to be able to use any lights you want on the same trunk by just popping them in.
                      this is not about being cheap, i have a 92 93 trunk in my garage but what i wanted to do was be able to fit 90-91 lights when i felt like it and 92-93 lights when i felt like it without going to the hassle of removing the whole trunk.
                      if i wanted ONLY 92-93 tail lights then i would have just swap my trunk out don't you think?
                      take a closer look, what flaws do you see in my trunk?, it sits perfectly when you look at the done picture, once you screw it in if you did it right no one will be able to tell
                      none of my cb7 buddies noticed even after i told them
                      as the title says "make your trunk universal" not swap it out
                      My MRT
                        good idea, i might try that next
                        My MRT
                          well those are the lights i used to show you guys what i did, but with this same steps you obiously can fit in the OEM lights as well
                          My MRT
                            water tights? there is already holes behind your tail lights, drilling other holes wont make water go in if water wasn't going in in the first place.
                            Ive had this for about 6 months and haven't had a problem with water.
                            there is really no flaws in what i did, other wise i would have just sealed the holes i drilled, and put my old lights back on.
                            i was having a hard time deciding what trunk i wanted because i like 90-91 tail lights but i also liked 92-93 tail lights, and now i can put any type i want in less that ten minutes
                            My MRT
                              Sweet write up! That is a VERY good and useful DIY.
                              I had no idea this could be done. You would have saved me about $100 buying 2 trunk lids doing 2 trunk swaps on my old car had I known about this.
