Originally posted by abdulmo86
EXT: Not getting your antenna ripped off in a carwash DYI
First you have to take off the middle piece of trim where the trunk latch is.
Then pop the cover off for the tail light and remove the 4 10mm nuts (you'll need a deepwell socket).
Once the 4 10mm nuts are out, remove that whole plastic panel. Then you should be able to manuver the plastic panel that covers the antenna motor enough to where you will be able to splice in wire and run it up front
