Hey whats up guys I'm doing this DIY for people who want to install the the CD5 lip.
But first here is a link to how to remove the rear bumper.
http://www.cb7tuner.com/vbb/showthre...bumper+removal
Tools needed
12MM Socket+wrench
Screwdriver
Drill+bits
Dremel
Since the CD5 lip is a 3 piece lip it actually makes the install easier.
Note that the CD5 lip is more of a curve then a box shape,
1.What you would have to do is cut with a dremel where the the lip curve's.
This is the reason why you cut the curve
When you bend the lip the top pokes up
2.Now that you cut the curves out they're ready to mount. When you have the lip at bend for the bumper drill a how and mount a screw to hold the lip in place. make sure that its flush with the bumpmper before drilling.
3.Once you have the lip mounted take a mark and mark where the holes line up for the sides of the bumper.
When done drill a hole big enough to attach the lip hardware.
This is what it will look like when done.
The lip comes up short but can be covered up with rear mudflaps
Tell me what you think guys. I know it's not the best DIY for this but I was by myself when I did itso it was hard for me to take good pics.
Tools needed
12MM Socket+wrench
Screwdriver
Drill+bits
Dremel
