This is courtesy of Lightning Motorsports
Start by removing the bolts that secure the intake box and intake vacuum box assembly
Remove the bolt from the rear of the airbox
Remove the (2) vacuum lines, electrical connector, and vacuum box
Remove the lower resonator attachment screw and note the intake tubing to be removed in the next step
Loosen screw-clamp, remove airbox and lower piping
Using pliers, remove clamp on breather hose
Loosen clamp and remove vacuum line
Remove intake hose and pull the breather hose loose from intake; remove intake
Remove vacuum line (previously attached to vacuum box) and detach from throttle body. Cap with supplied vacuum cap.
This is the port to cap off. We also have the vacuum line, disconnected earlier, that we will install the filter-foam into.
