Originally posted by PRIMOCB7
thanx for the tip...since i cleaned up the iac, the idle has been alot calmer...still waiting for my ecu(JDM F22B DOHC)...it should help the car run alot smoother...anymore advice, lemme know...you know your stuff...thanx
I'm going to clean my IAC and my ERG since I'm also getting cel code 12 (ERG) I was running very rich for about 2 week.
tip for you guys since doylna had a problem. sometimes there is soo much crap in there that it gets stuck inside, so only spray one time in the IAC very VERY little(if u have balls then spray more).....i made that mistake too and ended up with a currupted idle...i hope doylna's car is doing fine...
at first, clean the screen DONT REMOVE IT ..just clean it with a tooth pic...
spray inside the whole where the PGFI and where the IAC origionally connected to as well...i stuck a q-tip in there to clean around it but DO NOT DROP IT IN...that would suck!
*remember spray some cleaner on the Q-tip
i should clean mine again, but this time ill post step by step pics...would that help?
