ENG: Diagnose a Check Engine Light and S/D4 errors.
    My green S light throws codes, wheres the list for that?
    wat?
      i found the clip but there no light on it i dont get what you guys are doing?..
      Project EX Coupe Coming Soon...
      ..::Built not Bought::..
        i dont get it my car has the clip but no light..?
          Clip but no light?
          By clip do you mean the service connector? The thing you jump to pull your codes?
          When you jump that, the CEL will blink if you have codes stored.
          Only early model CB's had the little light in the ecu that blinked. Don't worry about that. Just do it the old fashioned way.
            just put a paperclip or a peice of wire in there. its very easy. then check the flashing engiine light in your gauge cluster.. and btw im from vancouver wa originally
            Member Ride Facebook
            XBOX LIVE = RedDragonsFool
            SOLD MY CB JUNE 16, 2009
            For Sale Thread
              Help!!!
              I have a 92 EX coupe with Stick. I have had the sold yellow Check Engine light for two weeks.
              Found this thread, and pulled back the carpet and kick panel... I cannot find the Blue Plug. Each harness under there from the ECO to up and around the heater box and kick panel has a home, and all appear to be large connectors than pictured.
              Chris
                its not under the carpet. It's closer to the door, under the dash.
                  I even pulled glove box to help see behind there as well. Where does the other end of the cable come from?
                  Chris
                    Chris
                    I went to this site attached
                    http://home.earthlink.net/~michaelpk...owTo_Codes.htm
                    I found a connector exactly where pictured. It appears to have 6 black wires coming into it, has 6 sets of sockets on it that mate to what looks like a ground with 6 pins on it.
                    Wazzupwitdat???
                      it's that blue, 2-pin.
                        D112Crzy-
                        Thanks man-
                        I just got back from the Boneyard and found the connector on some that were there. I found the other harness it is taped to as well.
                        Come back home - look at mine- find the #$%^ harness it is suppossed to be taped to...
                        and the bloody thing is not there. I have started to pull out the blower box and heater box to see if it is tucked WAAY up in there.
                        I did find both ends of the harness the thing is taped to- and no luck.
                        Do all years have these things? Mine was made in 12/91
                        Chris
                          Uhhhhh-
                          Found the $$%^in thing- tucked waaay up near where the top nuts are on the blower box. I could start to se the colrs of the wire and kept on tuggin- and I could see them going straight up to the top of the dash.
                          Thanks for the replies...
                          Now to diagnose my CE light.
                          Chris
                            i replace my o2 sensor this afternoon, after checkin my cel after to make sure i cleared the code, it turns out im throwin code 10 and 13 as well, im still workin on figurin out whats up with 10, but the atmospheric pressure sensor is stumpin me. any advice?
                            For Sale Thread
                              for resetting the ecu, cant i just pull out the 7.5 amp fuse in the fuse box?
                              MY CB7
                              FULL part out thread:
                              http://www.cb7tuner.com/vbb/showthread.php?t=204494
                                I pull the ecu and the backup to reset
