the idle is fine now, i just had to adjust it, one problem i found was the cruise control vac line came unplugged which was a huge problem... the problem ive pretty much diagnosed is a bad tps sensor cuz i tried setting it and couldnt get where it needed to be... but i have a new one i got off someone that ima put on this wensday. ill try to remember to update progress.
ENG: H23 Intake Manifold Swap (56K die!!!)
Originally posted by OttoHey! Where have all the pictures gone?
Anyone able to resurrect them?
Originally posted by nostringzcan someone tell me if the f22a1 is compatible for f22b intake mani?
i'll remind you the a1 has no butteryfly valves, and the f22b does...
Originally posted by sulimedi knew........just seeing if you did
Yeah! I get an A! LOL!
As for actually doing it, it is pretty straightfoward. Pretty much remove and install in the reverse of removal. All of the differences in the coolant hoses etc, should be posted in my H series plenum swap thread.
