Hello all. I am going to be installing a new oil pan. Haynes says after you drop the pan to remove the oil pick up tube. Is this needed and why? Thanks
Oil pan install??
Originally posted by F22HBI removed it and clean it out with brake clean. There is a screen in the pickup that you might as well clean while its apart.
Its an option and its not hard. Its like two 10 or 12mm bolts to take off the tube not hard.
YOu have to drop the pipe.. Just remove the bolts where it meets the upper manifold. It's flexible so you don't have to remove it all.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
