redline problem
    redline problem
    my car just started acting up. it won't go past 4500 rpm. if you try to go over 4500 it sounds live the rev limiter comes on. i have a f22b dohc with a p39 ecu. if some one could please help me. i origanally thought the motor had gone in to limp mode. but i don't get a check engine light. i even tried to flash the ecu and there were no codes.
    how are your grounds?
    how does it drive?
    try using another ecu and see if that solves it.
    Is there a loss in power?
      When is the last time you changed your fuel filter?
        i just finished checking all my grounds and they all appear to be fine. i tried switching the ecu and it was the same.
          the fuel filter was also changed less than a month a go
            also check the dizzy that happned to me once but it ended up being a loose dizzy
            member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
              That was the same problem I had. I thought it was the timing belt. The second dealer dianostic told me it was my dizzy. Exact same symptoms.
              The Lord watches over me!
              - D. Chappelle
                Sounds like the igniter, atleast mine did about the same thing and that was it. It is in you dizzy.
                -1991 Honda Accord LX H22a-
                  That happened to me and it was the crank position sensor which is also in you dizzy.
                  1993 Accord EX
                  2011 Subaru STi
                    Well I just replaced the whole thing. That way I can avoid any future problems down the road. Or for who ever buys it for that matter.
                    - D. Chappelle
                      did you ever fix it...
                      I have the same problem its just at 5500 rpm, I've changed all the ignition parts fuel parts except the EGR and the ecu, I dont know what else to do
                      Mr. $3 Dollahz Himself!
                        hmmmm crank position sensor? I'm having this stumbling upon startup issue, used to have the High rpm bogging but do you think the CPS would cure it? and does it only go bad if a CEL is on?
