Okay now I installed my shifter assembly off my accord into my prelude. Now the thing is Im not sure why of the shift now I know the blots dont line up so i took the bolts off the assembly and continued on.
First I took the old accord shifter assembly out and took the prelude assembly and put that it by sliding in the bolt so that it only lines up at the top right the rest of the holes dont line up all that great. So i tried putting a bolt through the rest they wouldnt work cause its at an angle the way the bolts line up. Now I filled in the rest with some plastic wire ties.
Now it holds in without all the shimmying now my release bearing is now fucked up but thats what happened before when I got my engine swapped now thats done now its fucked again because of a non expert installing it. Now Im going to a proffessional to do the shit right. Is there anyway I can get it to hold if modify it without any accessive drilling. I like the way the shifter sits.
