smells like........
    smells like........
    when i step on the gas it will start smeelin like burning oil or gas im not sure why.. one of my fans is out could it be that cuz its not coolin the motor right please help!!!!!!!!
    Backyard Customs
    Originally posted by xprojectcb7x
    why would you think people at auto zone would know what they were talking about?
    Building Fund: $0
    http://www.cb7tuner.com/vbb/showthre...="0" alt="" /> CLICK IT!!
    exhaust leaks will launch fumes into the cabin when u hit the gas. maybe its that u are smelling.
      Check around your fuel injector area, maybe your injector seals are leaking. An easy job to replace...
        its an exhaust leak
        my car does it
        93 Accord SE no tranny:Parting out
        http://www.cb7tuner.com/vbb/showthre...52#post2070752
        86 Ford Ranger fuel problem
        Explorer Fund:$1595.23
          teen spirit!
          My other ride is your ex-wife
            well you need to isolate wether or not it's fuel or exhuast fumes your smelling they are significantly different. unless your car is heavily modded and/or running rich as hell due to another issue. jack the car up so you can get under it and support it with stands and check turn the car on and listen and feel for the leak in the exhaust. most people don't have access to an evap/smoke tester to fill the exhaust with smoke to see if there is a leak. but check there first in addition to the above mentioned injector seals also check the fuel feed line banjo fitting to be sure it's tight and not leaking
