i swear i have a never ending problem with my brakes no matter how many times i try to fix it. like recently when i back out of my garage and hit the brake pedal the sound if something loose comes together causing a "banging" noise in the front? something sounds like it needs to be tightened but i cant figure it out?
strange noise from brakes
lol im glad your sig was not an accord!...but a bang noise when brakes are applied?? .........
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
well i have all new motor mounts, except the rear main ( which i recently checked and looked good). my brake on the other hand is pure shit in my opinion (but i'm a picky person ) my pedal has a lot of travel to start braking and is spoungy. these blows my mind too, because i have replaced the master cylinder twice. all new brake pads and rotors. all was properly bleed and adjusted, but my finally problem is my rear drums are warped. im lost right about now...
1. Check Fluid level
2. Make sure everything is tight. (I just saw a Grand Am come in with its caliper fallen off and jammed in the wheel) The customer complained about banging then it wouldnt move and there was the situation.
3. Rebleed.
4. Pull rear drum cover off and check the seals that push the drum. If its wet you need to replace that.
