Ok i have a issue where when my doors are open the light on my dashboard won't light up and also my ceiling light doesn't work when my doors are open.The ceiling light only works when i turn it to the on position.The open trunk light comes on on my dashboard.The lights on my doors don't even light up at all. Help!
Dashboard light issue
if you can, try to take the bulb outta the ceiling light. I know I had to mess w/ my vanity mirror bulb one time before it started working. It could just be a loose connection. But take it apart and look at the tabs, maybe one is not making contact with the wires or something.
member's ride thread
91 Accord SE 176k
it may look fine, mine did, but it didnt work. with the door open just jiggle the slider around to try and make a contact and see if it lights up on the dash or if your dome turns on. most likely thats what it is.
Hola, tengo tres patas. Me llamo tripod.
Originally posted by d112crzySo you're throwing a bitch fit because some other girl at school has the same nail polish and skirt as you do?
Originally posted by bagoon316it may look fine, mine did, but it didnt work. with the door open just jiggle the slider around to try and make a contact and see if it lights up on the dash or if your dome turns on. most likely thats what it is.
Didnt have to use any finger energy. He did it all for me.
both of mine didnt work in the coupe, so i went to a yard and took like four of them off different ones, and probably after a solid of month of them working my ex, shut the damn door with the seatbelt still in it, and broke the damn tab off. i was so mad lol.
as stated your switches arent working. you can usually clean em up and make sure that the point they screw in is clean and not rusty.
but to verify get a digital mulitmeter or test light. the wire connected to the switch will meter ground when the switch is let go and not with it pressed in (leave it screwed in)FA1
355
