If you are referring to the corner lights, pull them straight forward. Theres two little plastic tabs (that break off very easily) and a clip. It just needs some encouragement to come off. The first time I removed mine I had to use a screwdriver to pry them loose and I broke both plastic tabs (no tears shed).
Former: 90 Accord EX Coupe, 93 10th Anniversary in Frost White
1985 Volvo 245 manual [IPD lowering springs, IPD sway bars, OEM Virgo wheels, 1977 quad round headlights, 1978 grill]
2001 Mazda B3000 SE 4x4 extended cab [stock except for CB radio]
2008 Ford Escape XLT [bone stock]
2015 Toyota Prius Three with solar roof [rear diffuser, Vision Cross wheels... cheaper than steelies!]
