removing signal lights
    i am trying to take off the signal lighs. took off the screw on top but they won't fucking some out. wtf am idoing wrong.
    its a 90 accord ex.
    If you are referring to the corner lights, pull them straight forward. Theres two little plastic tabs (that break off very easily) and a clip. It just needs some encouragement to come off. The first time I removed mine I had to use a screwdriver to pry them loose and I broke both plastic tabs (no tears shed).
      yup, both of my clips broke as well. But when you put them back in, the corners will stay with just the screw. It'll be fine
