crabon tracking in distributor cap
    i decided to inspect inside my cap and rotor since the cb feels a bit sluggish. i've changed it out before, and pretty recently if i may say. so, i take off the cap and i see a nice thin white coat of white dust on one side. not only that, but there's a bit of oil that seemed to have made it's way through. i've seen the carbon tracking happen before, but the oil? is it coming from the distributor itself, possibly a bad distributor o-ring?
    ps - i'm going to replace the cap and rotor with oem parts, but while i'm at it i just want to kill this oil leak
    Replace the o-ring, they go bad.
    My swap thread
    Main relay proplems?--DIY
      Yep change the seal in the dizzy, and you might as well do the bearing while your in there at the same time
      My 5.7 LS1 Holden Ute
        i hear Honda doesnt stock the bearing seal. any idea where i can get a quality one?
          I'm pretty sure they do stock it, that's where I bought mine.
          My swap thread
            i'll check my local dealers. i know when i looked on majestic's website i didn't see it.
              x2 they still sell them. They might just have too order it in from another dealership.
                Did you click on distributor? It's there, #6 on the diagram for '92/'93. Anyways they never remove any parts from their website listing when unavailable. You will find out if its unavailable after you try ordering it.
                My swap thread
                  will it be the same for a 90/91?
                    #6 is the rubber o-ring gasket for the distributor. the other seal is behind that o-ring, inside the housing. it's like a bearing
