My cars been down for a couple weeks because of the work im putting into a new swap. I have an F22a1 bottom end that im rejuvenating. I am installing new Main Bearings, Thrust washers, Rod Bearings, and Piston Rings. All the parts have arrived and now im just doing some intense research of the operations im going to be performing. Ive gotten as far as taking the Oil Pan off, and the Girdle. I dont want to rush things and screw up, so are there any tips for doing all of this work, This is going to be my first time doing internal block work, specifications are almost 0 tolerance when it comes to installing bearings, so any information would be greatly appreciated. Would a Haynes Manual be a good investment for all of this?
I'm used to doing swaps, but swapping and block work are obviously 2 very different things.
All in all, what are some useful tools that i should rent from autozone to make my life that much easier?
Like I said, any information and input from you guys will help me out.
Thanks Again,
Luke
Luke
