Plz Help!!! Crankshaft Pully???
    Originally posted by 91 DX
    yea but it says from cp mike that there is a rubber seal ... i think thats my problem
    yes.. you'd be better of replacing the whole crank pulley and i think that rubber seal/dampener is non-repairable..
    here's another link that might help you out..
    http://www.cb7tuner.com/vbb/showthre...t=crank+pulley
      I see correct you are.
        thanks man ... i have a feeling this is going to be a BITCH!!!! but still thanks for the links
        The local asshole, 19 years in the making and still not giving a shit
        Originally posted by mj213
        Wait... don't you have a carbon fiber hood? You need to give your "bro" a cunt punt.
        Originally posted by bizzyboi
        He will defend his stance on raping his car to no end.
          it wont, if you have an impact wrench in hand.. gl
            do you know if i need a puller or anything to get it off ?
              i believe you just wiggle and tap it out after you're done with the bolt..
                apparently there is a special Honda Crank Pulley tool to get the bolt off. I have heard that AutoZone or other parts stores may rent this tool. just from experience. I would definitely use a impact gun.
                  put the car in 5th gear. have someone hold the brakes. get an impact socket, braker bar, cheater bar(thick & long one), and a lot force.
                    If you have a welder, you can just make that tool... We did. You can use a large hex pipe cap or pipe busing and weld a handle on it, and then cut a hole in the center of the pipe cap so you can get to the crank bolt. Ghetto, but it works suprisingly well. Just make sure to get a long enough handle, or make something that you can add a bar to, because you have to be able to exert as much force on teh handle of the holder as you do on the wrench you use on the bolt.
                    1992 Prelude S w/swapped H22A
                      This tool helps tremendously.
                      http://www.amazon.com/Alltrade-64879.../dp/B0000TMLWQ
                      My swap thread
                      Main relay proplems?--DIY
                        here is where i got my crank pulley
