Hey guys i really need some help fast !!! Ok so my altinator was going out and we got one today and started putting it on ... me and my dad got to looking at the crankshaft pully and the little side had gone in where the belt goes on ... So we got to calling around and no one knows ... i think my pulley is broken ??? if so how can i get to it to get it off ... we think thats what canned my alt. T previous owner said he thought it was mounted on rubber seals ? Could they have gone bad or something??? If they are even there ??? PLZ HELP!!!! any advice ??? tips??? i wanna get her back on the road!!!
Plz Help!!! Crankshaft Pully???
Last edited by 91 DX; 12-31-2007, 02:59 AM.The local asshole, 19 years in the making and still not giving a shit
Originally posted by mj213Wait... don't you have a carbon fiber hood? You need to give your "bro" a cunt punt.
Originally posted by bizzyboiHe will defend his stance on raping his car to no end.Tags: None
well unfortunately with the CB's to get to the crank pulley requires you to take the driver's side mount off and to support the engine from the bottom and slowly lower th drivers side until you can see the crank pulley bolt from the wheel well. Here the link:
http://www.cb7tuner.com/vbb/showthread.php?t=55332
Originally posted by blue93cbwell unfortunately with the CB's to get to the crank pulley requires you to take the driver's side mount off and to support the engine from the bottom and slowly lower th drivers side until you can see the crank pulley bolt from the wheel well. Here the link:
http://www.cb7tuner.com/vbb/showthread.php?t=55332The local asshole, 19 years in the making and still not giving a shit
Originally posted by blue93cbYou mean is the pulley mounted on a rubber mount?The local asshole, 19 years in the making and still not giving a shit
Originally posted by casterX"the little side had gone in where the belt goes on ... "
any actual pics?The local asshole, 19 years in the making and still not giving a shit
Originally posted by blue93cbno the pulley is not mounted on any rubber mounts. I have seen pulley's bent or even chipped trying to remove the pulley.The local asshole, 19 years in the making and still not giving a shit
Originally posted by blue93cbI'm thinking when you say "little side" you mean the grooves where the belt would slip into on the pulley?
no on the pulley you have the side where the altinator belt goes ... down from that you have the one where the power steering pump .... i could move the pulley today when i pushed on it help any???The local asshole, 19 years in the making and still not giving a shit
...no there is no harmonic balancer just one nut. And if you could move the crank pulley back and forth by hand that is not good. Not sure on price, however, I actually have a pulley from my F22 that I swapped for a H22. Ironically, the person I bought the car from had a probelm with the pulley not being tight, so the pulley has been sitting in the driver's side floor.
Originally posted by casterXThe local asshole, 19 years in the making and still not giving a shit
Originally posted by 91 DXyea but it says from cp mike that there is a rubber seal ... i think thats my problem
what does it require to take it off puller??? anything???The local asshole, 19 years in the making and still not giving a shit
