sports drive
    i raced a gs eclipse today...i beat one before..but didnt notice a difference...just when the light hit red..and then it hit green the tranny shifted quick with the sports mode and i took off...i was rolling to the light if u can imagine...
    i was surprised how fast i got up to speed....but blah its just for fun hehehe
    Retro!
    Hater
      I drive with the sport button around town most often. It let me downshift to the lower gear till 6000RPM in any gear. That mean If I'm crusing 30 mph in D4 that 4th gear at about 2000RPM, with the sport button on and I floor it, the tranny will downshift to 1st gear at 5300RPM and hold it till 6000RPM and upshift to 2nd gear and hold till 6000 to shift until 3rd and 4th. with the sport button off, it will downshift to 2nd and hold till about 5000RPM.
      I guess with a camshaft and valve train upgrade and a chiped ECU, we can make the auto shift to any gear and hold it till new redline of 7000RPM. so that mean you can floor it from 40mph from any gear and if the engine speed of 1st gear has not pass the sport button reprogramed say at 6800RPM then the tranny will kick down to 1st and burn some rubber.
      COme to think of it, U will also need a tranny upgrade from levelten.com or else your tranny will die quick like this.
      Just my opinion, 2 cent
      90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
      < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
        gas
        does driving with the sports drive on eat up more gas? gas prices here in Mass. are a bitch
          yes it wil use up more gas, since u will be 3/4 to full throttle most of the time. But that just me the sport button is not design for fuel economy, it meant to be hard driven around town
            got 210 miles on sports mode for my tank LOLZ...but i was mashing it alot as well....and i just changed the fuel filter and forgot to reset the ecu =)...
            Retro!
            Hater
              Why did Honda do away with the "Sport Mode" button on the 92-93?
                I think we at the board came to the conclusion that being at WOT will shift just the same...and for the accords' target audience it was unneccessary and potentially causing some confusion for the owners.
                  I agree that both WOT and "sports" mode does not make a difference in performance. We have a 91 SE automatic and it seems to pull the same mashing the throttle or in sports mode.
                    in sports mode if im not at full WOT the tranny stays in gear a bit longer and stays in the lower gear if im in a neighborhood so that it can pick up better.
                    but thats at NOT FULL WOT
                    i just do it so i dont have to mash it, i just press the button and it gets up a bit higher at normal acceleration cause it shifts longer =)
                    Retro!
                    Hater
                        Are you restating your question? Or admitting defeat in the search for an answer?
                          Actually, i want to know why lol
                            I would say it was removed because it was unnecessary
                              ok, i'm going to add my useless .02 I keep hearing people say that theres really no diff in performance between the sports mode and regular settings, I notice a huge difference, other than smoother transitions between gears while driving 30-40mph (instead of the constant shifting when in regular setting), I reallly pick up a lot more speed while I'm in "S" mode...theres clearly a big difference here, what we need to do it put 2 cb7s headsup, both with the "s"mode on, and then one run with the "s" mode off, then only run one cb7 with the "S" mode on...see what happens, I bet you the CB7 with the "s" mode on will smoke its competition.
                              list of my mods: suicide cup holder, arm rest stolen from fold down arm rest in the backseat switched to the front!: custom RUST and DENTS:: removed heat shield...lmao...I hate being a stock noob...don't worry, I'm learning FAST!!!!!
                                Seems to me, if they are both WOT, they will run the same...but thats just a guess, no facts behind it.
