Alright so last saturday I swapped in the f22a6 it started up fine 3 times. So now my cel,battery, and oil light doesn't light it bright it's dim and all it does is click thats it! Every other light is bright except for the cel, battery, and oil light!
Car not starting now!
Originally posted by accord91lxcheck and re-check all grounds. epically thermostat ground.
It was a bad main earth wire connection from the chassis to gearbox.
And yea check that thermostat ground, It causes all sorts of problems
My 5.7 LS1 Holden Ute
All of those are good every ground is hooked up, it started last week and now it doesn't the cel, battery, and oil light on the gauge cluster is very dim, the fuel pump isn't priming on the before starting. Im going to change out the main relay tomorrow when I get home from work!99 GS300 (Aristo) 2JZ Power
Bought from:gdout, bb6-sh
is it cranking over slowly if so replace the starter fixed mine but as for the dim lights check the battery and the connections
Engine:
stock F22A4
Cold Air Intake
2.5in Exaust No Cat toTip
Interior:
Short Shifter
Exterior:
5% tint all the way around
15in gun metal with crome lip rims
DIY jdm black headlights
Future Mods:
DSM Turbo
Yea and when I tap the starter it doesn't spark or nothing only the chim come on that's it! I put the new main relay in and all! I don't remember pinching any wires over the week. It's just crazy how it started last week when I got the motor in and now it does even do nothing, I'm holding power the battery is fully charged all grounds are hooked up. Like I said before that the cel, battery, and oil light are the only ones that are dim on the gauge cluster. There is no clicking to the starter now, the fuel pump isn't priming, but I have full power!99 GS300 (Aristo) 2JZ Power
Still sounds like a bad earth problem, Double check all the earths, even if they are tight, there can still be a bad connection.
Try put a voltmeter against the motor and the chassis. When I had a bad earth (same symptoms as yours) I was getting 12v on the block, I was like WTF
Then after spending an hour or so on it scratching my head. I removed the earths, and found the culprit - Poor connection, not loose, just poorLast edited by evil_demon_01; 12-18-2007, 12:20 AM.
my car did that too.... turns out my starter went bad. it did nothing but click but not come on.... got another starter now we are a-okay!Member's Ride Thread
Originally posted by deevergoteDon't forget to cut holes in the box. Someone sent me a dead hooker one time, and that wasn't cool.
Sold/Gave To: 90goldcoupe | CB7lx91 | Jas_r34 | F20accordturbo | BatmannamtaB
