Radiator Mystery...
    Radiator Mystery...
    So this is the 2nd time for me having this occur...
    Both times...after driving...i shut off my car...and i hear my fan trying to cool the engine...checked it and noticed the Coolant Resevoir is empty...i was like wth?...THIS has never happend--in my head--...anyway that was like 2 weeks ago..
    Just yesterday..it did the same thing again!..So im wondering..do I have a leak somewhere? Because if i DO...how come i dont smell any coolant? ADvice?
    I was thinkin maybe i need a flush?? idk...cuz it's been awhile since i can remember, it was like when my pops did it.
    *Needs*
    -New shocks
    -Struts
    -Drop
    -Cleaning
    -New Tires/Wheels
    -New Window Tint
    -Alot more lovin'
    better case senario: a leaking hose
    check every hose to see if even a small amt is filtering out, you should see white'ish around certain parts of the hose
    worse case senario: blown headgasket or bad water pump
    the water pump is easy, just time consuming
    head gasket is the worse, this can be check by doing a block test
    "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
    I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
      A flush is certainly not gonna fix your problem, common sense should tell you that.
      You need to make sure your radiator and overflow are completely filled, and then monitor them both to see if you are losing water.
      Then go from there, check for hoses, then at the water outlet, up near the throttle body, and under the timing cover.
      What I do is just park on a cardboard box for a couple of days, unless ALL the water burns off, that would tell you where the leak is coming from.
        is your car running hot? what about your radiator itself? is it topped off with coolant all the way to the top?
          i already did all this, hence..the "mystery" part. ...thanks for trying anyway.
          *Needs*
          -New shocks
          -Struts
          -Drop
          -Cleaning
          -New Tires/Wheels
          -New Window Tint
          -Alot more lovin'
            yes to all those questions..
            *Needs*
            -New shocks
            -Struts
            -Drop
            -Cleaning
            -New Tires/Wheels
            -New Window Tint
            -Alot more lovin'
              Sounds to me like your fans aren't working right, causing the water to boil, hence all the water you lost.
              The most likely thing it sounds like to me is a bad radiator though, if your cooling system isn't circulating water it will cause the water to boil, and overheat.
                Boiling coolant isnt going to evaporate, thats what the overflow is for lol
                Try getting a new Radiator cap, Thermostat,
                If you have an Automatic, check the tranny fluid
                The Tranny Cooler and Coolant radiator are both in the radiator
                My coolant system works so good my car wont heat up rofl
                Your man for wiring solutions!
                CB7Man's Coupe H22 Swap
                CB7Man's Sedan Resurrected From The Dead
                  MY fans come on rite away when i shut my car off.
                  And comes on durin drivin.
                  But ill def look into a new cap.
                    what is your temp gauge reading?
                    member ride thread
                    DIVULGE MOTORSPORTS
                      No, but it could boil out of the overflow. And if he is running mostly water, it could evaporate.
                        If the water was boiling, it should start filling the overflow resorvoir.
                        Since his overflow is full and it seems like his radiator as well, he is losing coolant somewhere.
                        - Tstat housing leak
                        - Radiator leaking
                        - Radiator hose leak at one of the joints, the lower hose joint to radiator is common (clamps can loosen up or hose dry rot)
                        - Water pump leaking out weep hole
                        - Heater hose leak
                        - Heater core leak, but you'd get passenger footwell leak & coolant smell in car
                          all coolant...no water.
                          *Needs*
                          -New shocks
                          -Struts
                          -Drop
                          -Cleaning
                          -New Tires/Wheels
                          -New Window Tint
                          -Alot more lovin'
                            cap is already replaced and new and shiny.
                            *Needs*
                            -New shocks
                            -Struts
                            -Drop
                            -Cleaning
                            -New Tires/Wheels
                            -New Window Tint
                            -Alot more lovin'
                              well funny thing is...one of my fan WASN'T workin...so i already have a new one on there and this happens..so im just clueless as to why this didn't happen when i had the rattling fan on before.
                              and to answer Turbo90accord's question....my temp gauge is a stock gauge and is reading between half way and a lil above half way ...higher than it averagely is for me.
                              *Needs*
                              -New shocks
                              -Struts
                              -Drop
                              -Cleaning
                              -New Tires/Wheels
                              -New Window Tint
                              -Alot more lovin'
