My girl just got done from letting my car overheat and went above the (H) as she told me. I told her to pull over she did not listen. She came home with a hose that busted. I replaced the hose then took it for a test drive. I got back tried to start it but no start it only turns over. I replace the Distributor cap and rotor and I got something this time but it will still not crank on. I pulled the plugs out and the plugs where soaked in gas. Cleaned them up still nothing. Im not to sure what I should do at this point. I really dont wont to take it in to some odd mechanic to tell me something I could have done. So please help me out. Im open to any suggestions.
Problem will not start.
Your girlfriend is retarded sorry to say...Why the hell did she not stop...I dont know why people dont listen pisses me off now your gonna spend a lot more money trying to get it to run right. Hope nothing is warped but probably is depending on the extent she drove on H.
Check for spark?
Originally posted by wed3kso did you tried to replace the plugs and check for spark?
Originally posted by NAiL05Your girlfriend is retarded sorry to say...Why the hell did she not stop...I dont know why people dont listen pisses me off now your gonna spend a lot more money trying to get it to run right. Hope nothing is warped but probably is depending on the extent she drove on H.
You said fuel if your sure do what wedek said. Could have fouled the plugs as mentioned.
shes retarded for that
tell her since she doesnt seem to listen that your gonna use the money that you had set aside for her christmas presents to fix the car. if she gives you lip then dump her cuz she only concerned about herself.
hey maybe she fried your ecs sensor with the engine getting so hot.
any check engine light. at worst do compression test or vacuum guage to see if anythings warped. check the coolant and oil. any chochlate milk?
xLast edited by xfactortype1; 12-09-2007, 07:08 PM.
Originally posted by NAiL05You said fuel if your sure do what wedek said. Could have fouled the plugs as mentioned.
Well I got her started several times by turning the key in the 1-2 position a few times. The motor still sounds strong but when turning it off it will not turn back on with out having to turn the key hundreds of times in the 1-2 position.
Originally posted by xfactortype1tell her since she doesnt seem to listen that your gonna use the money that you had set aside for her christmas presents to fix the car. if she gives you lip then dump her cuz she only concerned about herself.
x
Check your fuel filter. The fact that it starts after turning the key on and off several times is telling me that fuel is having a hard time getting to your motor. Fuel filter is the most likely cause for that.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
Originally posted by foamypirateCheck your fuel filter. The fact that it starts after turning the key on and off several times is telling me that fuel is having a hard time getting to your motor. Fuel filter is the most likely cause for that.Last edited by dualacord; 12-10-2007, 01:46 AM.
