I get 11.9 at idle.... 13.7 highest at wot and it gets richer in vtec. Never anything constant. Get it re-tuned?
Afr
Originally posted by preludeman92What are you basing this off of? I hope it's a wideband and not a light show gauge. You might try calibrating the wideband sensor.
Short of that, a retune is necessary. It shouldn't be richer at idle that WOT.
Originally posted by ChIoVnIdCawide band o2 ..... Like once a week I will get a o2 sensor cel when its real cold. And it will run at 17 a idle
What ecu are you running? That's very rich. ~13.5 is where WOT should be the entire time, not just before vtec.
Originally posted by d112crzythat sounds like you have a faulty o2 heater circuit with your wb.
What ecu are you running? That's very rich. ~13.5 is where WOT should be the entire time, not just before vtec.Last edited by ChIoVnIdCa; 12-06-2007, 12:45 PM.
You can disable the o2 sensor and the o2 heater in crome.
From what you're saying, I'm guessing they're not disabled.
When you say cold, do you mean cold as in weather or engine temp?
Could be that your o2 is bad and doesn't warm up fast enough so the ecu throws a code 1.
Originally posted by d112crzyYou can disable the o2 sensor and the o2 heater in crome.
Could be that your o2 is bad and doesn't warm up fast enough so the ecu throws a code 1.Last edited by ChIoVnIdCa; 12-06-2007, 01:40 PM.
When tuning, you disable the o2 sensor.
A lot of tuners choose to turn it back on because they don't tune partial throttle. I don't. I tune everything. I leave it off.
Advantage of turning it off? You don't have to worry about replacing an o2 or having any o2 related problems.
Disadvantage? if your tuner didn't tune it, then you'll be rich as hell.
