ignition coil....no start
    well car dont start,getting fuel,its turning over but no spark,what does the ignition coil look like so i can test it,does it have the positive + and negative - signs on it oris that something else i have aq 91 so its internal butr were is it in the dits? is it the rdctangle pice with the signs or is itsomething else need to know asap thans.
    i believe the part is called the Ignitor. I had to replace mine about a year ago.
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
      Take the plug wires off and remove the 3-4 screws (#5) holding the black plastic distributor cap on...then there is a rotor the holds down a plastic looking cover (#9), take a screw driver and pry (GENTLY) it off. The remove the 2 brass screws (#20) holding the ignition coil in the dizzy cap.
      Unscrew the 2 wires leading to the coil (#18 and 13) and pull out your ignition coil (#16). To test to see if the coil is good/bad get out a voltometer and I don't remember the resistance but check between the positive and negative posts (where the 2 screws went) and also between the positive and the coil.
      That is the best way to describe it. If you look in your chiltons it will also give you a step by step along with ohm readings
      CHILTONS or helms = blessing in paper
      No more cb7, 7 years of ownership and 196K on the ticker before she was sold
      Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
      NREMT-B | 300D and some glass
        ya my car was ideling and itjust died,it turns over strong but no startmi am going to the junkyard tommorrow to get one with low mileage.thanks.thats all it could be because its getting fuel,but no spark.thanks
          you sure its not the main relay?
          Originally posted by fizzbob7 i think the "jdm everything" craze is funny........it's the same thing, a fad.......and an overpriced one at that
          Originally posted by uncle_el believe it or not, this forum is not about you or your post count. it's about providing relevant information and exchanging it with one another, in order to help build a community. if you don't like that, please leave.
            ya i think it is the coil,still no spark i will get one from a junkyard for $5 but it beats paying $75 for a new one,and if it dont work i getanoither used one.but ,my firend did the same thing andhas been driving on a used one for 3 yrs.
