h22 bogging down HELP
    well fawk im havin same problem still. i have seen so many problems like mine but never the same fix......... dizzy is new, fuel filter is new, spark is all new,added seafoam and fresh gas still bogging down from 1500 rpms to 3000rpms no one can tell me anywhere. not even a ase honda tech its pissing me off?
    i have so much money into this bogging im going nuts!
    if it bogs to much ill get a cel 23 for KS. but not all the time...
    someone help!!! only thing have not replaced is
    tps
    knock
    egr
    main fuel relay
    but if you add all that up parts wise its close to a grand grrrrrrrrrrrr
    <img src="http://www.tagmy.com/image/40/louisv1/ff5/fruitopia/+layinsparxx+.jpg">
    Is the timing set right.
      tps
      knock
      egr
      main fuel relay
      simple trouble shoot: take the vaccum line off of the egr valve and run it like that.
      just try it it worked for me. i just dont know the fix so mine is unplugged until i can find known working egr to test!.
      .............................-----------------93 Ex Coupe[/COLOR]-----------------
      My CD7
        do a compression test
          my compression is fine, pull of egr vac and does nothing different.
          what should he have done with that bogging down issue? MY CAR DOING SAMETHING but im not boosted on. But it actually acts the SAME WAY i have changed so much and am lost
          Shoot me a call if you can help.
          it has no power from 1500rpms to 3000 rpms and all spark has been replaced including new fuel filter and sefoam treatment in gas tank.
          not popin any CEL's unless i run too long with it bogging and back firing.
          ANY HELP would be great!!!
          Thanks 360 440 6042 Brian
          Layinsparxx@aol.com
            Layinsparxx@aol.com
            you have PM!
            NOTE: what Nelson ( Nail05 ) mentioned...
            what I PM'd you about...add in the timing!....( that is also included into ignition )...without it being timed right... it wont run right....
            DING! check your timing belt and timing parts...are they old and loose?
            check your timing belt for slack!
            if it jumps time...might want to check the belt..tensioner spring and tensioner!
            theres alot that goes into timing! ( use a timing lightgun ) to check your timing while its running! ( timing hole ) ...make sure its within 15 degrees.
            MR Thread:
              wtf. did you not see my post? im starting to feel like im invisable.
              My CD7
                i seen post, i have been through my EGR al ready and even replaced it with new one. Cant be EGR. im leanin to TPS or main fuel relay malfunction
                  Tps ftw
                    you figure out the gremlins yet?
                    MR Thread:
                      Originally posted by CB7PWNAGE
                      Tps ftw
                      thats what I told him in a PM!
                      to check the TPS as well!
                      MR Thread:
                        ok here is update
                        NEW TPS
                        NEW EGR
                        NEW MAIN FUEL RELAY
                        CAR STILL MESSING UP
                        ROCKIN 36psi of fuel! i cant figure it out......Any onw want an accord lol j/p im mad as hell!
                          Check your timing???
                            i have the same problem and i have done the same things as u it is damn annoying
                            plzletmeknow if u figureit out
                            WTB: edm rear fog, 88-91 ef 4dr
                              Timin Dead ON
