Clutch Help
    Clutch Help
    i just did a a6 swap in car.... everything done except clutch isnt workin..i press the clutch down and it doesnt come up at all. Also when you push the clutch the clutch arm doesnt move at all?? Everything is hooked up What the hell?
    Sounds like you didnt bleed the system enough try bleeding it again if the problem still persists you might have a faulty slave or master cylinder.
    I need a 14b or 16g turbo!
      x2 sounds like the master cylinder
      SOLD!!
      Boosted H22
      375whp 298 ft/lbs at 15psi
        i bleed the system and the everything worked fine before the swap...how would it just go bad
          Possiblities:
          1.) Incorrectly attached/missing throwout bearing
          2.) Failed hydraulics (master or slave cylinder)
          3.) Broken/incorrectly installed clutch fork
          4.) Improperly bled hydraulics
          Those are the possiblities, check the obvious easy on's first. But those are the only things that can cause that.
          Proud owner of the only JJDM full 2.5" catback exhaust!
            Ok well I didn't swap an engine in my car but I have the same problem. Someone told me that my clutch may be going out. I don't want to have to replace it cause I don't have the money. Do you think it could be anything else or is it the clutch going out?
            Maple50175 - you're annoying =P
