Okay Suspension Noise when turning RIGHT!
    okay
    the owner told me it's the Control arm
    a mechanic i know told me it's the Bushing
    okay here it is
    when you turn to the RIGHT you get this THUMP!!
    and when you straighted the wheel BACK again you hear it AGAIN
    and if you turn the Wheel ALL the way to the RIGHT!! you hear this Noise like if the wheel was hitting the fender or something but it's not hitting nothing
    the aligment is GOOD the wheel Shakes a tiny bit nothing MAJOR
    what do ya think it is ?
    could "i" change it with Simple Tools i have
    Ride: 2002 Lexus IS300
    and if you could get me some pics of the bushing or whatever it IS
    and simple intructions (for dummies) on changing it
    Thanxx
      Sounds like upper ball joint. Could be lower too. Search for it.
      Gary A.K.A. Carter
      [sig killed by photobucket]
        by all these threads your making about fixing this and that Id almost think you bought a car that wasnt really in very good shape.
        Could be:
        -upper or lower ball joint
        -inner or outer tie rod
        -sway bar end links or bushings
        -lower control arm bushings
        thats my list...if its not one of those...somethings wrooooong.
        JDMRIDES.ca
          Thanks
          i was told to jack it up and take the wheel off and to like move stuff around
          and i could probally identify the problem you know
          like Stuff that looks Cracked or something
