are you guys sure we don't have a trans filter because at advanced auto parts they have one for our cars.
transmission filter
u dont its a screen....only when ur tranny goes down.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Don't worry about the filter, just change your automatic or manual trans. oils/fluids when you're supposed to (~ 30,000 miles ) and you'll be fine.
Automatic:
Dexron/Mercon III ATF ( I use Valvoline)
Manual:
10W-40 motor oil (I used Valvoline for this as well) or Pennzoil Synchromesh (haven't tried it, but heard good things from many people).
Note: In doing what I stated above, I've had no issues with trannies in both our 90 EX (manual) and 91 SE Accords (auto).
i change mine everyy 12 to 15k.
due to the fact that it shifts differnt aroun there...its cheap and fun =)What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Its been proven for motor oil, if you go on long drives all the time(freeway miles), that you can do oil changes ever 4.5k miles
and if you do alot of intown driving you should change it every 2k miles....
as far as the tranny fluid... ihave no idea.. 10k sounds good to meH22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Originally posted by OM617
The Haynes manual intervals are 3K for motor oil and 30k for ATF, and the official Honda intervals are longer. So 10-15k for ATF is a little over doing it for normal driving.
well dude i work as a pizza delivery. all i do is drive all afternoon. this is intown. which means a lot of fucking stop signs and lights.are we there yet are we there yet are we there yet
