I been trying to get these off for like 30 min already. I got like 4-5 of em off, but I fucked up one socket wrench, and 2 sockets already. I started with a 14 mm, 12 point, but I switched to a 14 mm, 6 point. Is this right?
F22A4 head bolts
you should loosen them all first before removing. This prevents excess pressure build up and less chance of warping any metal. You migh have to go around more than once to equalize the pressure. There is a certain order of doing it. This is what the service manual dictates. Use a long breaker bar with a 6pt socket not socket wrenches.
...adjust accordingly
Well, I'm using a socket wrench, with a pipe on the end as a breaker bar, which should work fine, but I guess I must be using cheapy sockets or something, I bent like 3 of em. I've never had a problem with these sockets before.
I might just go grab an impact from somebody and use that. I threw all the sockets I bent down the street cause I was so pissed, so I think it is time for an impact, lol.
